daniellejoi
Jan 31, 2021Follower
Need help setting time limit for internet usage on my AX12 - RAX120
I really need to set time limits for my kids internet access, simply want the wifi to stop working at 10pm. All i can find so far is to manually shut it off of each and every device i need it paused for. there has to be some other way than doing this manually. I just came from a previous router company for better performance which i am getting so far, but this is a HUGE downfall to not have the access to set up a control THIS EASY. How was this missed in development? please advise ASAP
1 Reply
> Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
RAX120[v1] or RAX120v2? Look for "Model" on thr product label.
> [...] All i can find so far [...]
Where did you look?
> [...] this is a HUGE downfall [...]
Before getting all indignant about the shortcomings of the router,
you might try exploiting a widely neglected resource:https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Set up a WiFi schedule".Further reading might not hurt, either.
