Rt62
Jun 16, 2019Aspirant
Need help setting up a VPN on a AX12
Hi just setup a new RAX120 AX12 and i'm looking to get a VPN setup on it do you have any suggestions and what will work on this router?
michaelkenward
Jun 17, 2019Guru - Experienced User
If you don't get any answers, it may be easier to start with the VPN and ask for advice on putting it on your network.
