Anay0810
Jan 06, 2020Follower
Need help with connecting phone line to RAX120
Hi, I was wondering if there is any way to connect a telehone to the RAX120 router. This has 4 RJ45 networking ports. Would it help if I use an adaptor to convert RJ11 into an RJ45 and then connect...
- Jan 07, 2020
Anay0810 wrote:Hi,
This has 4 RJ45 networking ports. Would it help if I use an adaptor to convert RJ11 into an RJ45 and then connect it to the router?
Why do you want to connect a phone to the RAX120? What are you attempting to do here? The RAX120 is not a dsl modem and doesn't have DECT built into it.
If you want you can make an adapter but it isn't going to do anything other than maybe wreck your router.
If you want to connect a phone to a router you need something like a voip setup or a router designed for phone service.
Jan 07, 2020Guru - Experienced User
Anay0810 wrote:Hi,
