WDW12
Jun 05, 2019Follower
Need model guidance
I currently have a Linksys E9500. I am considering replacing it with one of the Wi-Fi 6 routers but I have no way of comparing specs with the Linksys. I see that your Wi-Fi 6 lineup consisted of ...
slompochomp
Jun 05, 2019Guide
Well it looks like you answerred your own question, I'd say grab the Nighthawk AX4 and if you feel it's not doing what you need return it and get the AX120 or AX200 when you can aford it. Truth is the Linksys E9500 is a Tri Band router and the AX4 is not so it would sorta be a downgred for you. I am currenly testing the RAX200 which is a Tri-Band router also and I would suggest you get that when it is released. It is expansive, but if your looking to future proof your network it's is well worth it.
RAX200
- michaelkenwardJun 06, 2019Guru - Experienced User
slompochomp wrote:
.... I would suggest you get that when it is released. It is expansive, but if your looking to future proof your network it's is well worth it.
Sound advice. Might even wait a bit. The AX series seems to be "work in progress". Various bug reports and missing features.
The whole AX thing seems to be public beta at buyers' expense.
Give it time to settle down.
