Dean_
Feb 07, 2023Tutor
Need nighthawk AX6000 to speed over 1gb with virgin media
Hello all, in the uk I have virgin hub 5 which gives me 1 gbps of internet. I have connected this to my pc with a upgraded network card of 2.5gbs Network card says 2.5gbps Now when I put the virgin ...
Feb 07, 2023Guru - Experienced User
Ok so the ISP modem has count them with me 1, just 1x 2.5Gb WAN ethernet port. All other ports are 1Gb ports.
The RAX80 has all 1Gb ethernet ports. However the WAN port and the next door port can be LAG configured to get a combined 2Gb connection speed if you have a ISP modem that can also LAG it's WAN and another port next to it for LAG support with a router like the RAX80.
The RAX80 does NOT have a 2.5Gb WAN or LAN ports. There ALL 1Gb. So the most you'll ever see between the RAX router and your ethernet adapter is 1Gb connection rate.
There is LAG support on the LAN side with two of the LAN side by side ports however you need another adapter to connect and have them support LAG on the LAN side. You would see a combined connection of 2Gb only.
Dean_
Feb 08, 2023Tutor
Yes correct, the isp modem has 5 ports and one of them is 2,5gbps
Then on the nighthawk, all ports are 1 gbps
Is there a newer, maybe better router from Netgear than what I have , that ports are above 1gbps ( 2.5gbps)
So I can upgrade
Also Thankyou for your help
So I can upgrade
