Ford8725
Nov 24, 2020Follower
Need part number for a/c adapter for AX4300
n/a
michaelkenward
Nov 25, 2020Guru - Experienced User
Netgear does not sell replacement power adapters. Any generic adapter will work, as long as it has the right volts, enough amps and a tip with the right (+/-) polarity and dimensions.
Look at the device you own. It will have a label that shows what you need.
The manual will have the information too.
Plug the details into your favourite on-line store, or visit a local shop.
