plz_respond123
Feb 19, 2021Aspirant
Need to buy power adapter for my router
I need help in buying power adapter for my router. I lost mine when I moved. I live in Japan and bought mine at Amazon Japan so if anyone could link me an amazon.co.jp link of power adapter that...
plz_respond123
- antinodeFeb 20, 2021Guru
> Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for
"Technical Specifications" and "Power adapter". Then look for something
with the desired ratings and connectors.- antinodeFeb 20, 2021Guru
You might also check the ratings in the manual against the ratings
printed on the product label.- plz_respond123Feb 20, 2021Aspirant
Best info I could find in the manual and doesn't tell me anything
Power adapter North America: 100-120V, 50/60 Hz input
UK, Australia: 220V, 50/60 Hz, input
Europe: 100–240V, 50/60 Hz input
All regions (output): 19V/3.16 ADC output
