jmhga44
Oct 28, 2023Star
Need to open port 8081 for security camera access away from home network
I am trying to set up my laptop to access my security cameras when I am away from my home network and have found that my IP address is blocking port 8081 which I think is a needed port to access the ...
Can you reach the camera on the LAN while connected to the LAN or on the RAX wireless network?
Where is the idea coming from you desperately want to use 8081/TCP instead of the 37777/TCP you said before?
If 37777/TCP works on the LAN and you like to use 8081/TCP, put this port as the WAN / Internet facing port number, while keep the destination pointing to the LAN IP on port 37777/TCP. This is named port translation, perfectly valid.
