RandallDenning's avatar
Oct 30, 2023
Net gear AX 1800. ModelRAX20. I reset my Router and now have no WIFI?
After resetting Router to factory settings I have no wifi. Suggestions?
  • michaelkenward's avatar
    michaelkenward
    No wifi in what sense?
    The LEDs are off? Every WiFi client you try throws up some sort of error?
    Have you tried pressing the WiFi LED/Button?
    Everything else OK?
  • plemans's avatar
    If you push and hold the wifi on/off button it needs to be held for at least 2 seconds
