TexasBrit
Aug 11, 2020Follower
NETGEAR’s Nighthawk AX5400
Will this work pugged into a combination cablemodem/wireless routr unit? My cable company no longer provides basic cable modems anymore and they all come with built in wireless capability tht cannot ...
LarryLeitzel
Sep 18, 2020Aspirant
Yes l know that. l need to know to find the "network security key number" so l can type it in to my computer. eather on cable compay provided cable modem or my netgear nighthawk router. witch one where
Sep 18, 2020Guru - Experienced User
If you changed it from the defaults (which can be found on the label) you can hardwire directly into the router and log into it. from there you can access the wireless ssid/password info.
