cefolar
Oct 23, 2020Aspirant
Netgear 5G Pro Mobile Router with Nighthawk RAX50
Working on setting up a Nighthawk RAX50 with the new Nighthawk MR5100 5G Pro. I did a factory reset on both devices and then plugged the WAN port of the RAX50 into the port on the MR5100 and everyth...
cefolar
So I may have figured this out (for others that have issues). On the MR5100 mobile router - I enabled IP pass through, turned off the DHCP server on the mobile router, disabled ethernet standby AND set the USB port for "charge only" << very important! Without it set as "charge only" the USB port still acts like a tether and doesn't enable the LAN port on the mobile router.
I let the mobile router cycle and my RAX50 recognized the internet and adopted the internet IP address of the mobile router, the DNS address from the mobile router and appears (at least at this second) much more stable. I'll update the thread if I have any issues. If anyone else has any thoughts glad to hear them.
Christian_R
Oct 28, 2020NETGEAR Employee Retired
Hello cefolar,
Thanks for providing an update on your post as it may help others.
Christian
