KadenJessop
Dec 21, 2022Aspirant
Netgear 6700AX AX1800 stuck at "Please wait a moment"
I have tried logging into my router and it's stuck at "Please wait a moment". Cannot click on any links in the interface. Router version is V1.0.13.128 which is currently the latest. What are th...
- Dec 22, 2022
Sorry to waste your time. I re-started the router and now i was able to login fully.
Kitsap
Dec 21, 2022Master
KadenJessop wrote:I have tried logging into my router and it's stuck at "Please wait a moment". Cannot click on any links in the interface. Router version is V1.0.13.128 which is currently the latest.
What are the solutions to fix this?
Start off with additional information.
Are you using a real computer or a mobile device? What operating system?
Are you connected to the router via an Ethernet cable or Wi-Fi?
Are you using an application or a web browser? Which version?
If a web browser, what address are your using?
- KadenJessopDec 22, 2022Aspirant
Using a PC on windows 10, via Ethernet.
Used chrome, Brave, Microsoft Edge, happens the same.
Address i used the default 192.168.1.1 then tried routerlogin.net, same thing happens.
- michaelkenwardDec 22, 2022Guru - Experienced User
And "the modem/gateway/ONT between the router and the outside world" is?
Did this just start happening? Or is it a new installation?
- KadenJessopDec 22, 2022AspirantFirst question, I don't understand what answer you're looking for.
For the second question, it started after about a week I set it up.
