KadenJessop
Dec 21, 2022Aspirant
Netgear 6700AX AX1800 stuck at "Please wait a moment"
I have tried logging into my router and it's stuck at "Please wait a moment". Cannot click on any links in the interface. Router version is V1.0.13.128 which is currently the latest. What are th...
- Dec 22, 2022
Sorry to waste your time. I re-started the router and now i was able to login fully.
KadenJessop
Dec 22, 2022Aspirant
Using a PC on windows 10, via Ethernet.
Used chrome, Brave, Microsoft Edge, happens the same.
Address i used the default 192.168.1.1 then tried routerlogin.net, same thing happens.
michaelkenward
Dec 22, 2022Guru - Experienced User
And "the modem/gateway/ONT between the router and the outside world" is?
Did this just start happening? Or is it a new installation?
- KadenJessopDec 22, 2022AspirantFirst question, I don't understand what answer you're looking for.
For the second question, it started after about a week I set it up.- KitsapDec 22, 2022Master
For the second question, it started after about a week I set it up.You connect your AX6700 with an Ethernet cable to some type of device to obtain an internet connection. Usually that device is a modem or a gateway (combination modem/router) or an ONT (optical network terminal). What device, brand name and model number, are you connecting your AX6700 to? You could also be in a apartment where all you have is an Ethernet receptacle in the wall.
Sometimes the web browsers (all of them) get confused or they confuse the router. It is helpful to clear the cache on the web browser. Each browser is different but it is an option in the settings.
Another course of action is to power down your router, pull the power cord, wait a few minutes and then power it up and give it plenty of time to boot and stabilize.
My Router is connect via ethernet to a Calix ONT, Don't remember the model # .
