Retired_Member
Nov 14, 2021Netgear Alexa Skill showing "Device is unresponsive".
Netgear Alexa Skill showing "Device is unresponsive". RAX200 with Firmware Version V1.0.5.132_1.0.69. All other Alexa skills/devices work perfectly fine, but the Netgear router always shows unrespo...
Nov 15, 2021Guru - Experienced User
what modem/gateway is the RAX connected to?
I've seen the alexa devices/skills perform poorly in double nat situations
- Retired_MemberNov 15, 2021I’m not entirely sure the modem the ISP uses, I don’t have access to it, however the cable that runs from it goes to a POE with no serial number / product identification of any sort, and then the cable from that goes to my RAX 200.
I also use a static IP.- plemansNov 16, 2021Guru - Experienced User
Not trying to be rude but that doesn't help much.
If you want to get the alexa services running (not a big deal), we need full info on the setup.
Again, its because many iot devices have issues with double nat's.
If you're not worried about it working, then I wouldn't worry about it.
If it is something you want working, we need to look into what you're actual setup is and the devices connected.
- Retired_MemberNov 16, 2021You’re not being rude at all.
It’s a completely valid request and I’m quite frustrated that i cannot provide more information. I’m quite familiar with networking myself and it’s pretty annoying not being able to access the ISPs modem as I’d be risking my life basically (and this isn’t that important lol).
The setup is ISP modem -> POE (with literally no visual identifiers AT ALL, now a letter or number anywhere -> my RAX 200.
I will attempt to contact my ISP over the phone however right now and see if perhaps they can shed some light on the equipment being used on my property.
- Retired_MemberNov 15, 2021I’m not entirely sure the modem the ISP uses, I don’t have access to it, however the cable that runs from it goes to a POE with no serial number / product identification of any sort, and then the cable from that goes to my RAX 200…
I also use a static IP.- Retired_MemberNov 15, 2021Oops double post due to lag. No idea how to delete.
