Retired_Member
Nov 14, 2021Netgear Alexa Skill showing "Device is unresponsive".
Netgear Alexa Skill showing "Device is unresponsive". RAX200 with Firmware Version V1.0.5.132_1.0.69. All other Alexa skills/devices work perfectly fine, but the Netgear router always shows unrespo...
Nov 15, 2021Guru - Experienced User
what modem/gateway is the RAX connected to?
I've seen the alexa devices/skills perform poorly in double nat situations
Retired_Member
Nov 15, 2021I’m not entirely sure the modem the ISP uses, I don’t have access to it, however the cable that runs from it goes to a POE with no serial number / product identification of any sort, and then the cable from that goes to my RAX 200…
I also use a static IP.
- Retired_MemberNov 15, 2021Oops double post due to lag. No idea how to delete.
