armylife4ever
Dec 03, 2020Follower
Netgear armor cax80
Every since i got netgear armor my internet has dropped from almost a gig to about 400 megs. Does anyone know how to fix the issues? Is there new firmware updates? It is ax6000 modem
1 Reply
Sort By
- Christian_RNETGEAR Employee Retired
Hello armylife4ever,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
