psychopomp123
Sep 29, 2020Luminary
Netgear Armor down?
I'm unable to log into https://armor.netgear.com at present, keep getting 'internal server error' message. Anyone else seeing this? Also I'm unable to re-activate Armor (paid subscriptio...
- Sep 29, 2020
Hello Kakashi28,
Thank you for the additional feedback! Can you confirm if this issue is now resolved for you for either the App or the armor.netgear.com portal?
Cheers,
Christine
ChristineT
Sep 29, 2020NETGEAR Employee Retired
Hello psychopomp123 and Kakashi28,
Thanks for bringing this to our attention! We are looking into it. We'll provide an update as soon as it becomes available.
Best Regards,
ChristineT
- Kakashi28Sep 29, 2020Aspirant
Thank you Christine,
The Orbi router couldn't connect to the Armor either. And when I logout and login to Bitdefender app on mobile or laptop it says my subscriton has expried. My subscription doesn't expire until Sept. 2021.
- TerryPhSep 29, 2020VirtuosoNoticed the NG Armor is behaving abnormally today. Subscription valid until Oct. 27, 2020 but the web site said expired.
Can you look at the issue Christine.
Let us know ASAP.
Thanks
