psychopomp123
Sep 29, 2020Luminary
Netgear Armor down?
I'm unable to log into https://armor.netgear.com at present, keep getting 'internal server error' message. Anyone else seeing this? Also I'm unable to re-activate Armor (paid subscriptio...
- Sep 29, 2020
Hello Kakashi28,
Thank you for the additional feedback! Can you confirm if this issue is now resolved for you for either the App or the armor.netgear.com portal?
Cheers,
Christine
psychopomp123
Sep 30, 2020Luminary
I can the confirm this is fixed now, now log into armor.netgear.com and have also re-activated Armour using my smartphone.
Thanks ChristineT :)
ChristineT
Sep 30, 2020NETGEAR Employee Retired
Hello TerryPh,
Can you please let me know if you're subscription is still showing expired?
psychopomp123 - Just to clarify so I can report back to engineering, you had to actually re-activate your service as it did not automatically re-active? What did you see before you reactivated the subscription?
Thank you both for your additional contribution to this discussion!
Kind Regards,
Christine
- psychopomp123Sep 30, 2020Luminary
Usually when a factory reset is done on my Netgear RAX200, it removes the Netgear Armor activation so you always have to re-activate after setting up the router again. I believe this is totally normal behaviour on Netgear Armor compatible routers, so this itself is not an issue. I have succesfully managed to reactivate Netgear Armor on my RAX200 many times previously.
However last night I manually upgraded the firmware on my RAX200 and then I did a factory reset - I always do this after each firmware update for peace of mind. After restoring the settings from a settings backup file, I then tried to activate Armor using my smartphone. It wouldn't let me activate this and i tried this 3-4 times but without success. I then went to armor.netgear.com to see if my subscription was still valid (it is) and only when I couldn't log online, realised the issue was at Netgear's end. So i guess there was a glitch somwhere at Netgear's end which was affecting both the login to armor.netgear.com and also reactivation of Netgear Armor on the router using a smartphone. I'm happy to report both of these issues have now been fixed by Netgear :)
- TerryPhSep 30, 2020VirtuosoYes Christine. It still shows the subscription expired at the link from Nighthawk app.
The subscription not expired until Oct. 27. 2020 supposedly - TerryPhSep 30, 2020VirtuosoYes, it still shows as of today Sep. 30, 2020 that the subscription is expired, despite my assigned subscription date should be Oct. 27. 2020.
Best
