Hard2Fix
Sep 27, 2023Follower
NetGear AX 1800
WIFi 6 Router… I have installed router but have one particular website it will not let me access. This is a site that I use at least three times a week. I checked with business owner and she conf...
Sep 27, 2023Guru - Experienced User
What model NG router do you have? RAX?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Does this happen across all devices?
Armor, Smart Parental Controls or Circle
