sclawrenc's avatar
sclawrenc
Apprentice
Jun 07, 2021
Netgear AX Routers as Access Points that Support Seamless Roaming?
Hello Netgear Community,
Does anyone know if you can use two Netgear AX1800 or AX3000 routers in Access Point mode with successful seamless roaming betweens access points with VoIP calls?  For example, maybe two RAX38s or similar?
My RBR50 and RBS50 do it fine, but I'm considering going to AX so looking into either a different (dual band) mesh system or picking up a couple of routers and putting them in AP mode.
Thanks in advance.  :)
S
  • plemans's avatar
    I'd go the mesh system thats designed for it. You could either go the orbi route with AX or the nighthawk MK systems.
    I haven't used either but if I was wanting seamless roaming on consumer gear, that's what I'd do.
    • sclawrenc's avatar
      sclawrenc
      Apprentice
      Thanks plemans for your response.
      I was hoping to use separate channels on each access point to maximize my bandwidth on each channel, and I wanted to the DFS channel support just in case.  Like you said, I also didn't see any explicit mention of 802.11 k/v/r support on any of the Netgear routers other than mesh or business class.  As much as as I like the simplicity of mesh, I don't like the fact that all of the units use the same channel for each band.  For example, maybe I want to set channel 1 for 2.4ghz on one side of my house since my neighbor uses channel 6 and then channel 6 on the other side since my other neighbor might use channel 1.  I know it's not a big deal, but just trying to maximize my signal across my home which includes outdoor Ring cams which are sitting outside my brick exterior.
      Thanks again.  :)
      • plemans's avatar
        to achieve what you'd want, you'd need to go with the business grade product.
