MSPSRMS
May 24, 2024Aspirant
Netgear AX12 RAX120 as Access Point
I replaced the RAX120 with a R700RS router and in the past had run a Amped Wireless AC2600 wireless extender to reach the outer limits of my structure. The amped device was configured with different...
- May 24, 2024
If you can get the switch into a multi gig switch and set the RAX for AP mode and connect it up using the multi gig port on the RAX, could see higher speeds over wifi:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
I would be sure to set the RS and RAX Wi-Fi channels to far apart channels to lower any Wi-Fi interferences from each other.
May 26, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
