Valcugen
Jan 21, 2021Initiate
Netgear AX12 RAX120 EU type plug
Hello, I would like to ask, where can i find a replacement adapter, i have purchased the router in the US while i was there for a business trip but i apparently have missplaced the adapter and now...
- Jan 21, 2021
Netgear doesn't sell replacement power supplies. But you can use a 3rd party adapter. Just make sure it has the same output voltage, at least the same amperage (can be higher), and the same polarity.
Jan 21, 2021Guru - Experienced User
Valcugen
From what i saw over the internet, i can get my hands on a US version 9v 3.16a and just use a US to EU adapter since from what i can see the US powerbrick is 100-220v, so just using a "tourist" adapter without any voltage converter will do the trick.
