Visver
Apr 11, 2020Aspirant
Netgear AX12 Unable to register Product Serial No.
Hi I just bought a brand new AX12 router, but i am unable to register the serial no. It keeps saying it is already registered to someone else. I purchased it sealed brand new. Please help.
- DominicanMacProApprentice
You can check the status here https://www.netgear.com/mynetgear/registration/Product_WarrantyCheck.aspx
that will give information when it was registered
Also I would say look at the article and submit the issue with netgear section
"I am having trouble registering at or logging into my.netgear.com..."
And be sure to send proof of purchase that will speed you're process up with this matter
https://kb.netgear.com/1160/NETGEAR-Product-Registration-FAQ
How does NETGEAR use my registered information?
NETGEAR uses your registered information to:
- validate support eligibility and hardware warranty
- assist in the support of your home network
- gather general consumer demographics
Send email to customer.service@netgear.com with:
- the subject line "Problem with my.netgear.com"
- the description of the issue you are experiencing
- your full name and contact information
Our Customer Service team will gladly work to resolve your problem!
I made a mistake entering my serial number or email address when registering...
- the subject line "Correcting registration information"
- a description of your issue
- your NETGEAR customer number OR your full name and contact information
- the product model and serial number
My product does not have a serial number - how do I register it?
(Applies to Home products only. Does not apply to ReadyNAS storage products)
If your product does not have a serial number, it has been refurbished. The serial number is not required to register your product. Send email to customer.service@netgear.com with:
- the subject line "Register a refurbished product"
- Product name
- Your NETGEAR customer number or full contact information
- TopologyVirtuoso
Visver, the serial number of the RAX120 is on an adhesive label on the router itself, as well as on the box in which the router was packaged. Is the serial number the same in both locations?
- VisverAspirant
I have the serial no. i purchased it brand new on ebay, and i am not sure if netgear will honor ebay email as proof of pruchase, is there a way to connect with some live to resolve this registration issue. I sent an email 10 days back and no one has resplied yet.
Ya u might have An issue with netgear buying off eBay they consider that not a auth reseller . I'll file with eBay did you get protection on this ?
It can register but you will lose the warranty that's the issue I had I'm getting rid of it
