cdoan
Mar 20, 2020Tutor
Netgear Ax120 connection issue
Hello guys! Got myself the AX120 router hooked up to Netgear CM1000 w/ Cox Gigablast Service. Every couple days, I have to restart my modem and re-configure my whole setup again as if I just...
- Nov 17, 2020
The R7800 would have been better for you. Plenty of info on Smallnetbuilders regarding this router.
Newfiedrool
Mar 20, 2020Virtuoso
Hi
There is a hot fix available to download.
https://www.netgear.com/support/product/RAX120.aspx#download
If this is installed or you install this it's then best to reset the router using the rear pin method on the back of the router.
Hold it in for about 20 seconds then allow the router to boot back up. Setup as new and don't use a saved config.
cdoan
Mar 20, 2020Tutor
Thanks! I will go ahead and do that.
So, I should download the Hotfix you linked and update it. Then reboot it w/ the reset button for 20 sec and re config as new?
- NewfiedroolMar 20, 2020Virtuoso
Yes download and update via the web UI. Let it fully boot up for say 5 mins then you will see the small hole on the rear of the router Marked reset. I use a paper clip for this. You will hear a small clich when you press it with a paper clip and just hold it there for 20l seconds then release.
give the router 5 mins to fully boot then setup again, I normally use the web UI rather than the app to setup.
Small click not clich. Wish I could edit the post 😊
