cdoan
Mar 20, 2020Tutor
Netgear Ax120 connection issue
Hello guys! Got myself the AX120 router hooked up to Netgear CM1000 w/ Cox Gigablast Service. Every couple days, I have to restart my modem and re-configure my whole setup again as if I just...
- Nov 17, 2020
The R7800 would have been better for you. Plenty of info on Smallnetbuilders regarding this router.
Weitefx
Jul 10, 2020Aspirant
I have excatly the same issue. Is the "hotfix' the latest firmware or is there another patch? If so, I have been running this version for a week and no difference in result. Keep losing connection to internet specially on WIFI. Nighthawk app shows "online" when I am not and frequently shows off line when ethernet still goes through. Any other suggestions?
cdoan
Nov 16, 2020Tutor
So after what was recommended, I did do it and still had issues. So I ended up getting a new router instead of the all the headache.
Now, I bought the Nighthawk x6s. Now I'm having connection issues and upate issues. Similar problem. I am about to give up on Netgear.
- NewfiedroolNov 17, 2020Virtuoso
