Rob_B71
May 03, 2025Follower
NETGEAR AX120 Router w/Bitdefender service
I have this router, and I also have the Bitdefender service for security w/VPN. I have noticed that the router does not have the VPN service running on it. I am wanting to get this VPN service on it,...
May 03, 2025Guru - Experienced User
Most home routers don't support any VPN installation features. Most VPN are services that pass thru the router. You'll need to make contact with the desired VPN service to see how to setup and use there VPN services.
Good Luck.
