aesop-riddle
May 21, 2023Aspirant
Netgear AX1800 not blocking
I have a Netgear AX1800 WiFi Router RAX10. I cannot block any websites. When I inquired, I was told to use the app. I do not want parental controls, I want to be able to block sites. Every router I'...
- May 23, 2023
OpenDNS did the job.
Thanks all
microchip8
May 21, 2023Master
if you're trying to block HTTPS sites, that won't work due to encryption.
- aesop-riddleMay 23, 2023Aspirant
Blocking these works fine by adding them to my Windows/HOSTS file. That's good for my computer, but doesn't help other router clients.
Thanks for your reply
Thanks all
