aesop-riddle
May 21, 2023Aspirant
Netgear AX1800 not blocking
I have a Netgear AX1800 WiFi Router RAX10. I cannot block any websites. When I inquired, I was told to use the app. I do not want parental controls, I want to be able to block sites. Every router I'...
- May 23, 2023
OpenDNS did the job.
Thanks all
May 24, 2023Guru - Experienced User
Enjoy. 📡
