crsb1960
Oct 26, 2022Aspirant
netgear ax1800
Netgear ax1800 power light blinks. What is the problem? Can anyone help with this?
michaelkenward
Oct 26, 2022Guru - Experienced User
When you turn a device on, it goes through a self test cycle.
As a rough guide:
- It blinks as it does some tests
- After a bit it then turns to a solid colour, usually white or green
- Wrong colour (red rather than white/green), or blinking = trouble
- crsb1960Oct 26, 2022Aspirant
Netgear 36. Blinks on start up but it still blinks after boot is complete.
- FURRYe38Oct 26, 2022Guru - Experienced User
Netgear 36 isn't a model #. Do you have a RAX### or EAX### something?
RAX10
- michaelkenwardOct 26, 2022Guru - Experienced User
That's probably the default SSID for your wifi.
Look here:
The label on the back.
