crsb1960
Oct 26, 2022Aspirant
netgear ax1800
Netgear ax1800 power light blinks. What is the problem? Can anyone help with this?
michaelkenward
Oct 26, 2022Guru - Experienced User
When you turn a device on, it goes through a self test cycle.
As a rough guide:
- It blinks as it does some tests
- After a bit it then turns to a solid colour, usually white or green
- Wrong colour (red rather than white/green), or blinking = trouble
crsb1960
Netgear 36. Blinks on start up but it still blinks after boot is complete.
- FURRYe38Oct 26, 2022Guru - Experienced User
Netgear 36 isn't a model #. Do you have a RAX### or EAX### something?
- crsb1960Oct 26, 2022Aspirant
RAX10
- michaelkenwardOct 27, 2022Guru - Experienced User
crsb1960 wrote:
RAX10
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual
Troubleshoot With the LEDs.
Back to your question:Netgear ax1800 power light blinks. What is the problem?
So far, the only thing we know is that the LED blinks.
An important question that no one has asked, is the router still working?
Can you login to the router's graphical user interface (GUI) with a browser?
How do I log in to my NETGEAR wireless router? | Answer | NETGEAR Support
- michaelkenwardOct 26, 2022Guru - Experienced User
That's probably the default SSID for your wifi.
Look here:
The label on the back.
