leaf_water's avatar
leaf_water
Netgear AX3000 / RAX40 detects lower bandwidth than link actually provides
My home is on Verizon FiOS with 400mbps up/down. I have an Ethernet line running from the ONT to my router, and the router backfeeds all of the coax in the house through a MoCA adapter. If I connect ...
  • leaf_water's avatar
    Oct 17, 2020
    Update: I tried a lot of stuff. I tried updating the installing the initial release of router firmware and updated through every release that Netgear had provided. No luck. I tried unplugging the ONT BBU and disconnecting the battery terminal -- didn't help. I spent a long time contemplating the graveyard of ISP equipment and the labyrinth of coax splitters they had mounted. I chatted with Verizon support: "Your router, your problem." No help here. No matter what I did, the WAN statistics in the admin interface read 100M (Full).
    I had figured that autonegotiation was failing (the WAN port itself was immaculate), but I didn't know how to verify that (those logs aren't visible) nor test it. In the end "WAN capped at 100ms" was the magic search-engine phrase to find the solution. SNB forums provided the solution -- stick a dumb switch between the ONT and the router. The ONT negotiates with the switch, the switch negotiates with the router, et voilà. Speed's up to scratch.
