Potato13
Jan 16, 2023Follower
Netgear AX6 PMF Settings
Hello,
I have a bit of a janky computer running Windows 10 on my network. The PMF (Protected Management Frame) settings keep triggering a BDOS. I want to get the AX6, does the AX6 have the PMF settings so I can disable them, or are they disabled already? I know the AX8 has PMF disabled by default, but the AX8 is out of my price range.
Thank you,
Potato13.
1 Reply
do you mean BSOD (blue screen of death)?
Have you tried simply getting a different wireless adapter?
Or uninstalling your current adapter and doing the stand alone driver for it?
