mayeen12's avatar
Apr 12, 2020
NETGEAR AX8 / RAX80 WAN/Internet Throttled - AVOID BUYING
My Router: Nighthawk RAX80 Firm V1.0.2.76_1.0.35 Internet: Cable 940 MBPS - I constantly get 940+ mbps when my PC is connected directly to CABLE MODEM Devices; 15-20    I'm annoyed beyond believe...
  • mayeen12's avatar
    Apr 17, 2020
    I finally fixed my problem
    Final Results, I'm getting FULL 940 to 985 MBPS download (From Internet & Internal NAS Drive) - both in wired and wifi mode.
    PLEASE NOTE** All my clients are wired or AC or AX devices.
    Step 1 - Get the latestest firmware
    Step 2 - Turn OFF QOS
    Step 3 - Turn OFF Traffic Meter
    Step 4 - Turn OFF Access Control
    Step 5 - Test you MTU with your MODEM from a wired connection MODEM <> PC  > https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
    Step 6 - Adjust your MTU settings >> https://kb.netgear.com/24015/How-do-I-change-the-MTU-size-on-my-Nighthawk-router
    Step 7 - Use WiFI Analizer - FIND THE BEST CH for WiFI - I put AUTO for 2.4 and CH36 for 5ghz
    Step 8 - ENABLE BEAMFORMING > DISABLE MUMIMO > ENABLE AX
    Devices; 15-20
    I'm annoyed beyond believe - i purchased by router Dec 2019 - 500 CAD$
    This router has mind of its own for the WAN PORT.
    There is countless people reporting this, I found this problem from the day i purchased it.
    If only i had known, i would have returned it than, back than i asssumed it was my internet being throttled by ISP
    What happens is,  the router is run for 1h at full speed wan, than starts throttling to 360 MBPS - wifi or wired. with QOS ON
    Than if i turn off my QOS, speed goes up to 480 mbps.
    THan if i trun back my QOS, speed goes up to 950+ mbps for few hours. until router starts throttling again.
    Everything else - wifi speed, AX speed 800+ mbps over wifi, internet network.  WORKS PERFECLTY --
    GOD DAM WAN is ONLY porblem only if you have Gigabit connection.
    THE DAMM TECH at netgear are bunch of jockers with their MTU settings and stuff..
    I wish i had returned it
