Chrisb755
Nov 24, 2024Aspirant
Netgear broadcasting 3 WiFi networks
I set up my router and named my main WiFi and Guest WiFi. Netgear also shows up and these broadcasts are linked to my router. I have no idea what the password is, how to stop them from showing publicl...
Chrisb755
It shows AX1800 on the bottom. I do see the SSID and it shows the name I set and has the password I set but I have no idea why these 3 Netgear wifi are broadcasting of how to dosable those from the public viewing. I have no idea even what password they are set to use. Very strange and I’d love to change it if possible
Kitsap
Nov 24, 2024Master
Chrisb755 wrote:It shows AX1800 on the bottom. I do see the SSID and it shows the name I set and has the password I set but I have no idea why these 3 Netgear wifi are broadcasting of how to dosable those from the public viewing. I have no idea even what password they are set to use. Very strange and I’d love to change it if possible
AX1800 is not a Netgear model number. Look on the nameplate for the words "Model Number", they should be followed by something that may start with R.
Did you attempt the setup process using a mobile device?
If yes, that is why you are in the situation you describe.
Once you find your model number, you can go to the Downloads section at the top of this page and download the manual. It will provide information on performing the setup process using a web browser and a computer.
