K0walskiK0rwa
Sep 27, 2019Aspirant
Netgear CM1200 to Rax200 WAN aggregation not working ?
Hi guys. Sorry for my bad english. I'm trying to connect my CM1200 with RAX200 using WAN aggregation. I'm following steps according to guidelines from the instruction and so far after a week of mu...
NorcalGuy80
Sep 28, 2019Tutor
Have you made sure to enable port aggregation in the modem itself? I ran into the same problem and realized I had not enabled port aggregation in the modem and it is not factory default to being turned on. After that, everything worked perfect!
