K0walskiK0rwa
Sep 27, 2019Aspirant
Netgear CM1200 to Rax200 WAN aggregation not working ?
Hi guys. Sorry for my bad english. I'm trying to connect my CM1200 with RAX200 using WAN aggregation. I'm following steps according to guidelines from the instruction and so far after a week of mu...
NorcalGuy80
Sep 27, 2019Tutor
Have you made sure to enable port aggregation in the modem itself? I ran into the same problem and realized I had not enabled port aggregation in the modem and it is not factory default to being turned on. After that, everything worked perfect!
K0walskiK0rwa
Yes i did, i turn on the enthernet aggregtion and is still not working.
Can you do me a faver and wright down how did you do it yours step by step.
i know im doing something stupid but i cant figure it out what it is.
- slompochompSep 27, 2019Guide
I connected my PC to Wan port 1 on the CM1100 and enabled Ethernet Port Aggregation on the modem first. Next I connected my PC to the Lan a port 2 on the RAX200 and then connected 2 RJ45 connections from the CM1100 modem to the RAX200 using the Mulit-Gig Internet/Lan 1 ports and then enabled Mulit-Gig Internet using the RAX200 GUI web interface from my PC.
- K0walskiK0rwaSep 28, 2019Aspirant
I follow yours steps and i have same problem. Just after connecting 2 RJ45 to the ports on the router side, it work for 30 second and rebot it self, work for another minute and reboot it self again and again. I have few screenshots so you could take a a look. BTW did you had to setup router MAC address ??
thank you.
