K0walskiK0rwa
Sep 27, 2019Aspirant
Netgear CM1200 to Rax200 WAN aggregation not working ?
Hi guys. Sorry for my bad english. I'm trying to connect my CM1200 with RAX200 using WAN aggregation. I'm following steps according to guidelines from the instruction and so far after a week of mu...
K0walskiK0rwa
Yes i did, i turn on the enthernet aggregtion and is still not working.
Can you do me a faver and wright down how did you do it yours step by step.
i know im doing something stupid but i cant figure it out what it is.
slompochomp
Sep 27, 2019Guide
I connected my PC to Wan port 1 on the CM1100 and enabled Ethernet Port Aggregation on the modem first. Next I connected my PC to the Lan a port 2 on the RAX200 and then connected 2 RJ45 connections from the CM1100 modem to the RAX200 using the Mulit-Gig Internet/Lan 1 ports and then enabled Mulit-Gig Internet using the RAX200 GUI web interface from my PC.
- K0walskiK0rwaSep 28, 2019Aspirant
I follow yours steps and i have same problem. Just after connecting 2 RJ45 to the ports on the router side, it work for 30 second and rebot it self, work for another minute and reboot it self again and again. I have few screenshots so you could take a a look. BTW did you had to setup router MAC address ??
thank you.
- slompochompSep 29, 2019GuideI setup the RAX 200 some months ago and I believe I did change the router's MAC to my PC MAC so that the modem would work corectly. I will have to check the MAC on the RAX200 later today. Also try the setup wizard and if that does not work try setting link aggregation manually.
- slompochompSep 30, 2019Guide
ok it looks like I am using the Default MAC on the RAX200, but you could try changing the MAC on the RAX200 to the MAC from your PC Network card because the modem may be locking in the MAC address from your PC Network card when you setup the Ethernet Port Aggregation on the modem.
RAX200 MAC
