K0walskiK0rwa
Sep 27, 2019Aspirant
Netgear CM1200 to Rax200 WAN aggregation not working ?
Hi guys. Sorry for my bad english. I'm trying to connect my CM1200 with RAX200 using WAN aggregation. I'm following steps according to guidelines from the instruction and so far after a week of mu...
4estOC
Jan 08, 2020Guide
I have a CM1200 modem and RAX200 Router with WAN agreggation (2Gig). My internet speeds slow down to 25Mb after approx 24 hours. Rebooting the router fixes the issue for another 24 hours and then the 25Mb speeds are back. I have to reboot my Router* once a day. This is incredibly frustrating!
Also* QoS seems to be disabled-unavailable when using WAN aggregation on my RAX200. (please fix this)
- K0walskiK0rwaJan 08, 2020AspirantI give up on setting aggregation after countless hours traying to. I did replace my router as well and encouraged same issue with download drops.
- branchbikerFeb 16, 2020Apprentice
If you disconnect Port 1 on the router (the 2nd aggregation) speeds return to normal. You don't actually have ot reboot the router or the CB. This is just an observation, nothing still that fixes the issue. There is now a case open with engineering to look into this.
