K0walskiK0rwa
Sep 27, 2019Aspirant
Netgear CM1200 to Rax200 WAN aggregation not working ?
Hi guys. Sorry for my bad english. I'm trying to connect my CM1200 with RAX200 using WAN aggregation. I'm following steps according to guidelines from the instruction and so far after a week of mu...
K0walskiK0rwa
Jan 08, 2020Aspirant
I give up on setting aggregation after countless hours traying to. I did replace my router as well and encouraged same issue with download drops.
branchbiker
Feb 16, 2020Apprentice
If you disconnect Port 1 on the router (the 2nd aggregation) speeds return to normal. You don't actually have ot reboot the router or the CB. This is just an observation, nothing still that fixes the issue. There is now a case open with engineering to look into this.
