K0walskiK0rwa
Sep 27, 2019Aspirant
Netgear CM1200 to Rax200 WAN aggregation not working ?
Hi guys. Sorry for my bad english. I'm trying to connect my CM1200 with RAX200 using WAN aggregation. I'm following steps according to guidelines from the instruction and so far after a week of mu...
K0walskiK0rwa
Mar 09, 2020Aspirant
So today was the last straw for rax200. This device stop connecting to the modem. I tray to factory reset multipletimes with no go. Tray diffrent wires with same results. IT got replace with my old R9000, and when all the updates on it was done is working like a charm and it is faster then rax200. If you take a look at the picure i did i have much better speeds that i had with rax200. Nothing is cut in half going thru router, and i had connected all external around 20 of them. Dont know what happen with it but as you can see from my post i had a lot of problems with this device. I dont know now, if the next router will be a netger or i will look for something else. Thank you for all you support communty, it was for sure much better then the customer service while it last.
4estOC
Mar 09, 2020Guide
If Netgear doesn't release new Firmware for their most expensive cable modem and most expensive Router soon, I will be leaving Netgear for good. They need to focus less on their never ending hardware launches are start putting good firmware support into the devices they sell. This is absurd the product does not work as advertised 6 months after release!
