K0walskiK0rwa
Sep 27, 2019Aspirant
Netgear CM1200 to Rax200 WAN aggregation not working ?
Hi guys. Sorry for my bad english. I'm trying to connect my CM1200 with RAX200 using WAN aggregation. I'm following steps according to guidelines from the instruction and so far after a week of mu...
Christian_R
Mar 10, 2020NETGEAR Employee Retired
Hello 4estOC,
May you perform the following and let me know if you run into any issues:
1. Factory reset the router by holding down on the reset button with a pin/needle for 15+ seconds
2. Enable port aggregation on the CM1200 and RAX200
3. Ensure the RAX200 is connected to the CM1200
4. Check the WAN aggregation status on the RAX200 admin page (the status should state "active")
Thanks,
Christian
K0walskiK0rwa
Mar 10, 2020Aspirant
Hi Christian
I perform all those steps multiple times with same results. So im done doing this. Like i said im back to my old device with much better performance after update the firemaware to newst version. Mybe i just goint to use this rax200 as a very expensive access point.
thanks.
