Clockwork100
Feb 22, 2020Aspirant
Netgear d850 vdsl not connected
Good morning please can anyone assist Hi I have purchased a Netgear D850 connected it to the adsl point and it connected but then rebooted and now says no adsl cable connected I use BT for...
Clockwork100
Feb 23, 2020Aspirant
Hi sorry yes its the 8500
The twisted light remains red and has the message when trying to use the wizard that the dsl cable is not present, I have connected the dsl cable to my old BT hub and it all works well and connects however the D8500 will not recognise that the cable is present. The previous owner only used the router as an access point so never tested the modem side of the router. I suspect that the modem side of the router is defective.
Thanks in advance for looking
michaelkenward
Feb 23, 2020Guru - Experienced User
Clockwork100 wrote:
The twisted light remains red ..
That amber light tells us that it is not "not connected to a DSL service, did not establish a DSL connection, or did not establish an Internet connection". But you knew that anyway.
Aha, so we are talking second hand.
I see no indication that you have done a factory reset on this thing, as suggested earlier. You should do that to wipe out any memory of previous internet connections.
You don't say what the power LED looks like. I did ask "What do the LEDs on the D8500 look like?"
- Clockwork100Feb 23, 2020Aspirant
Hi
Both the power light and the twisted pair light are both red
the wifi lights are white
if I connect to any of the rj45 sockets the corrosponding indicator lights and flashes
I have tried a reset a number of times
When I log into the router through the rj45 cable from my laptop I can access the router and if I try to use the connection wizard or manual setup I get the message that the adsl;vdsl cable is not connected
Thanks for trying to assist
- michaelkenwardFeb 23, 2020Guru - Experienced User
Your firmware is corrupt. That's what the red power LED means.
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
