djomega971
Aug 18, 2020Aspirant
Netgear Firmware FTP site
I seem to recall there used to be an FTP site that customers could use to download firmware from, but can't find anything about it. Does it still exist? I ask because the latest RAX80 Firmware Ver...
AwesomeTaco
If you got to the support page for your RAX80, you go fo to downloads and there is a drop down for older firmware.
https://www.netgear.com/support/product/RAX80.aspx#download
- djomega971Aug 18, 2020Aspirant
There is a section called "Previous Versions" which contains the previous two firmware releases prior to the current one. Nothing on the page that allows you to see or download firmware versions that might be older than that.
