rorton
Apr 01, 2020Aspirant
NETGEAR Genie
Will NETGEAR Genie work with the RAX200 router?
- Apr 02, 2020
If you mean the Android/iOS app, no.
Try:
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
If you want the desktop genie for Windows start here:
genie Landing Page | Apps | Discover | Home | NETGEAR
You may have to dismiss an annoying pop-up that tries to push a mobile app down your throat.
michaelkenward
Apr 02, 2020Guru - Experienced User
Try:
