PieterT
Sep 14, 2021Tutor
Netgear MK63 combined with Netgear R7000
Dear Community, I'm new to the netgear community and have a question about a purchase I want to make in the next few days. I currently have a netgear r7000 at home as my router. I would like to p...
- Sep 14, 2021
It won't integrate with your system but you can use it.
You can either go:
R7000 (router mode)---->MK63 (access point mode)
or
MK63 (router mode)------>R7000 (access point mode)
You need one of them in access point mode to prevent a double nat.
I'd also make sure ot use a seperate ssid and to have them on a seperate wireless channel to prevent interference.
I've done this numerous times.
Sep 14, 2021Guru - Experienced User
You can either go:
or
PieterT
Sep 14, 2021Tutor
Dear plemans,
Thank you for your reply and solution.
Which order of the two you just suggested would you recommend?
Does it make a difference in terms of internet speed which is set as router and which as access point?
Kind regards,
Pieter
- plemansSep 14, 2021Guru - Experienced User
If it was me? I'd try them both and see which works better.
the MK system is a lot newer (7ish years) and might perform better as the primary but until you try it, you never know.
