Jimmsy
Sep 13, 2024Follower
Netgear model rax29
I am trying to see if my router is compatible with a wifi connection and they need the imei number and I;ve spent the past 2 hours trying to find it. Does anyone have any suggestions/answers? Thank y...
Sep 13, 2024Guru - Experienced User
Jimmsy wrote:
I am trying to see if my router is compatible with a wifi connection and they need the imei number and I;ve spent the past 2 hours trying to find it. Does anyone have any suggestions/answers? Thank you
what do you mean by this?
Details are key. Explaning what you're doing, why you're doing it, and what devices you have that you're connecting them to is critical. What "wifi connection" are you attempting to connect the RAX to?
