HenriqueLang's avatar
HenriqueLang
NETGEAR Night hawk MS80
Dear fellows!
Purchased a Netgear Nighthawk wifi6 MR-80 with five MS80 satelites to use in my home.
One MS80 satelite cannot connect to my MESH network.
Tried factory reset, sync, etc. there is a strange white led blinking. Twice blinking alternating with one blinking.
My nighthawk android app shows me all 5 satelites, includind the last one that seems defective. But when I click in details  I can see it's Mac address, serial number, but no IP address and no firmware version.
I am suspecting some kind of firmware issue.
Is there a way to re-flash firmware on this satelite?
Cannot find any similar problem with this mesh and no solution.
Appreciate any help
Henrique
  • plemans's avatar
    I think at one time I'd read the maximum supported for the MK series was 3 but others had gotten more working.
    A trick that some had to use with the orbi system was to shut off the paired satellites to get the un-paired devices connected and working. then they turned the others back on.
    I'd try that first.
    Not many have that system so I haven't seen an official list or even many that have added that many.
    another thing to check on is if you're daisy chaining or star topology.
    Even orbi maxes out with daisy chaining 2x devices.
    DarrenM Any ideas how many maximum have been added or potentially can?
    • HenriqueLang's avatar
      HenriqueLang
      Thnaks helping me solving this problem. But actualy this mesh system support lots of satelites like MS80.
      I think that there is some issue concerning firmware. The behavior of  while led blinking is totally different from users guide.
      white led blinking is not as described in the manual. It´s blinking white twice alteranting with one time blinking.
      There is no information about this in the manual.
      factory reseting or trying to sync does not modify blinking behavior.
      I purchased router (MR80) and 3 satellites (MS80). Pairing was fast and easy. The 4th unit (MS80) paired fast. The last and 5th unit did not connected as supposed to do. This particularly MS80 cannot get IP address.
      I tried only pairing this satelite with router (MR80), but as soon it reboots, the strange behavior of white led blinkg starts again.
      Cannot find any solution in netgear forum.
      I suspect it comes defective, unfortunately.
      Thanks any way.
      Henrique
      • plemans's avatar
        are you able to access the MS80 using its default IP address?
        Push and hold reset for 7-15 seconds while its powered on. That'll reset it.
        The default ip address is 192.168.1.250.  you can hardwire a pc/laptop into it.
        If you can, try reinstalling the firmware to it. Maybe something is corrupt in the firmware.
        Then try setting it up.
        If that doesn't work, I'd either RMA it or exchange it where you got it.
