jaredvalenti
Jun 06, 2024Aspirant
NETGEAR Nighthawk 6-Stream AX5400 WiFi 6 Router wireless speeds are slow
My wireless speeds standing right next to the router are only 140 mbps. My ISP plan supports up to 500 mbps. I live in a small apartment less than 1500 sq feet. In the bedroom the speeds are 90 mbps....
jaredvalenti
I used to use a mesh system which got higher speeds when I used those routers but they were terrible for trying to play online games so I switched to this new router. So depending on the router, I get different speeds. My ISP is Spectrum sadly and my plan should support up to 500 mbps so I do not understand why my wireless connection is so slow to begin with and slower with this router than the mesh system
michaelkenward
Jun 07, 2024Guru - Experienced User
jaredvalenti wrote:
... they were terrible for trying to play online games
Wifi and gaming don't go well together. Wired is better.
