A_Payne
Aug 30, 2022Follower
Netgear Nighthawk AC1900 Version R6900v2 can't obtain ip address after restarting, works after facto
Hello, I'm hopping I can get some help figuring out what is going on with my Nighthawk. I've had it for about 5-ish years, and never had any problems until recently. Everything works fine until the po...
Aug 30, 2022Guru - Experienced User
If you're having that frequent of power outages i'd invest in a backup power supply for it.
I'd also make a backup of it.
You could try downgrading the firmware a version. I've seen versions sometimes cause issues with reboots.
