BostonRob777's avatar
Feb 20, 2022
Netgear Nighthawk App - all my options are gone
For whatever reason I lost all of the options on the home screen of the netgear nighthawk app. Parent controls (Circle), traffic meters, all are gone. I have no idea why.   I tried uploading the la...
  • BostonRob777's avatar
    BostonRob777
    Feb 20, 2022
    Problem solved. I unchecked "enable AP Mode"
    All the features in the App are now present.
    This was from the user guide.
    Set up the router as a WiFi access point
    You can set up the router to run as an access point (AP) on the same local network as another router.
    To set up the router as an AP:
    1. UseanEthernetcabletoconnecttheInternetportofthisroutertoanEthernetport on the other router.
    2. Launchawebbrowserfromacomputerormobiledevicethatisconnectedtothe router network.
    3. Enterhttp://www.routerlogin.net. A login window opens.page80image2204480
      Manage Network Settings 80 User Manual
      Nighthawk Tri-Band AX12 12-Stream AX WiFi Router
      1. Entertherouteradminusernameandpassword.
        The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive.
        The BASIC Home page displays.
      2. SelectADVANCED>AdvancedSetup>WirelessAP. The Wireless AP page displays.
      3. SelecttheEnableAPModecheckbox.
      4.
      5.
    4.
    5.
